Oil catch can recommendations
SARNCAN
I was asking because you want the hoses and even the can to be in a area that is warm. Even stock the hoses have frozen. Super rare but that said the aluminum can and the longer house do not help this.
As far as oils there are better oils but watch your oil pressure first. We have 2 stage oil pumps so low at idle isn't that big a deal but at full throttle what the pressure goes up to. There are many more important factors with oil then just increasing the weight to comp for heat. I just don't know what is available there.
On 9/18/2019 at 7:18 PM, 1SLOW1500 said:
Yes and no. In FI we need much more breathing so a tank is used with or without the catch can.
Issue is a single in an single out only covers the valley cover to the middle of the intake manifold.
So the issue is under boost the intake is under pressure and the check valve from elite closes. So now you get pressure. This causes many problem and more blow by. Now you did address the 2 large hoses in the valve covers go that sees the pressure and dents it out the engine to the intake tube. So now you have oil in the intake again.
Best to have the valve covers going to the catch can and the valley cover also. On a na engine. Can cleans and always sees vaccum.
On fi old school breathers and catch can on vally cover with 2nd port to before boost source.
So you see I have 3 breather lines to tank and then elite deals with cleaning just valley. When in boost check valve closes and the 2nd port goes to before turbo. Lots of vaccum there. Not that it is needed with my breather.
So in my opinion block off intake tube, jump passenger valve cover to driver side the css to elite. Clean it all. 57b7a96c57437a3e9b42a697eb052f12.jpg539323790d4fa50d75ed7978a529e26c.jpg59220c258bf40bc12d07ee7415aeb53b.jpg
Im looking at adding a catch can. Im supercharged. I can see where most of your hoses are routed and understand them. Where is the hose on your air intake tube pre turbo going?
Yes it is best to have a vaccum source so pre turbo for me. Also the issue is if you have the 2 ports on the intake tube for the valve covers. It is absolutely best to port those to atmosphere. Many supercharger guys have just a breather tank for those.
In my opinion very best is no PCV line goes back to engine. Catch cans and breather tanks for all. Then you can say zero oil can get to intake.
So I should be good running valve covers straight to breather tank and running a catch can. In side of catch can from valley cover and outlet to vacuum port on supercharger? With one check valve on inlet side? Sorry I’ve played around with this some and haven’t had great Results. Just wanna do it once and do it right
That is fine....well in my opinion it is better then most as the valve covers NEED to vent. So a breather tank for that is best option. You don't even need the check valve on the catch can line to the port on the supercharger as there is always a vaccum on that.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
