Active fuel management
SO my AFM bank of cylinders is running lean/rich
 the O2 sensor drops to ZERO volts   (Flat 0.00 volts)
so is it safe to assume the sensor is dead?
the V8 bank  runs fine    no lean/rich issue  at all
I think there may be some misinformation on your part.
When the DoD/AFM is active, there are 2 cylinder per bank that shut down. One half of the engine does not just shut off, it couldn't run like that because it would be so unbalanced with only the left or right bank firing. They have to keep using both banks but they just shut off cylinders 1,4,6,7 to keep the engine happy.
But to answer the question on the o2 sensor, if the sensor is dropping to nothing. It's a good bet to say the sensor is on the fritz and you should replace it. If problems continue you have a wiring issue on your hands.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
