2017 GMC Sierra Denali Vibration
Governor
I have recently developed a vibration in my truck. 86k for miles. Highway use only. Steering wheel is where I feel it the most. Tires replaced 20k ago with Michelin LTX. Zero trouble until today! Trans and drivetrain fluids to scheduled to be changed this week. Has the 8 speed trans. Does not pull left or right. Any ideas would be appreciated!
Felt it first time between 55/60 mph guessing in 8th gear on newly paved road. Have also felt in between 35/40 mph.
At different speeds we need to see if it is rpm based or gear.
The quick look overs are damage to the drive shaft but other then that and a leak of fluids. Hard to say where exactly. Also you can rotate tires just to see if fronts are damaged. Or rebalance as it is cheap or free.
Thanks! Rotate rebalance and fluid change is where I'm starting! Truck was fine yesterday just started today! No damage to tires at all! I just wonder if a front shock is a culprit.
Guessing your Magna-Ride shocks have died.
Lost both rears on our 16 Tahoe, rode like crap, replaced and rides smooth again.
2 hours ago, 1SLOW1500 said:
What speed mph,rpm, and gear.
Thanks for the info! Forgot they have different shocks than the norm! I will check that as well!
You are very welcome. Good luck, $1700.00 for the set, dealer installed with discount.
They do not give those shocks away for free.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
