09 avalanche
I'm working on an 09 avalanche. I changed the pads and rotors all the way around. Bled all four from the farthest from the master. Also bled the ABS module with the scanner and the truck still has no brakes. And foam is coming out of the fronts but it's a clear steady flow from the back. What is wrong ?
Have you been just bleeding it with someone pumping and holding the brake in?
You could try gravity bleeding for a while or using a pressure bleeder or vacuum bleeder to push/suck the fluid through the lines.
