tire Questions
I have a 99 GMC Sierra EXt Cab truck. 2WD
The tires on it now are 245/75/16. The spare is 235/5/16.
I'm looking to get new tires for it, It's not lifted or every will be, and seldom tooken off the streets.
Should I get 245/75/16 again for them again? Or go wth something a little bigger...I see the 265/75/16 are the same price. that would give it a bigger stance but is that working it, would it help any with towing that I due? And if I go bigger then the 245 up to 265 would I need to have the speedo changed?
thanks for any advice!!!
check out 1010tires.com
they have a tire size calculator
put in your OEM and then mess around with different sizes
it will tell you the exact difference and mph gain/loss
when you find the tire you like click at the top of tire #2
and they will give you a list of all manufactures and pricing
i have always found tirerack.com to have the best prices
and your local NTB will match their prices as long as its not
a closeout or clear out
:cheers::cheers:
