Fuel Trim
g2full
Alright, I'm lost.
Anyone local to York, PA with a scan tool that would be willing to meet up? Or have an idea of where to go next?
I'm trying to chase down a negative fuel trim issue on bank 2 of my 15 silverado 5.3.
MAF was lazy, replaced that. Which took me from a -20% fuel trim at idle to -13%. Injector Pules on Bank 1 are solid across the board however pulses on bank 2 are all over the graph.
None of my scan tools will dial in above 2013.
don't live anywhere nearby, but you may want to check for an exhaust leak between the engine and the upstream O2 sensor on that bank...or an intake leak...
Negative fuel trims generally means extra fuel. Positive trims would be an exhaust/vacuum leak because of the extra air.
I would swap o2 sensors side to side. If the issues jumps to the drivers side, then the o2 sensor is reporting incorrectly.
Upstream and downstream sensors? Or just the downstream? Looking at those on the scanner they appear to be tracking properly, but doesn’t mean they aren’t skewed.
I should have added that this fuel trim issue was discovered when the truck went in for lifter and pushrod replacement. No idea how long it’s been this way because it isn’t setting a MIL. But, it still isn’t right.
Is your truck a flex fuel. I had similar issues with my 08 tahoe. Ended up being an algorithm issue with the flex fuel virtual sensor needing to be reset. It was reading 56% ethanol and throwing off my trims but only on 1 bank.
Sent from my SM-N975U using Tapatalk
Non flex model.
So bank 2 injectors all over the place? Perhaps a leaky injector. Maybe check fuel pressure key on engine off. Should read around 55psi. That's all I got for now.
Will check that. I know on my scanner I can pick up fuel rail pressure, but there’s a lot I can’t do. I’m reading the truck as a 13 5.3 LC9 motor. I figure it might not be 100% accurate but it’s what I have access to.
If I can figure it out I will post a video tomorrow of both injector banks pulses.
You would swap the upstream o2 sensors. The downstream o2 sensors only report how the cat converter is doing.
The value the trims are pulling won't set a code because it's withing the range or normal operation.
You can't check fuel pressure like you want to. Your 2015 truck uses direct injection. A scan tool will show you the low pressure fuel pump readings and the high pressure fuel pump is under the intake manifold that is operated by a lobe on the camshaft to raise the fuel pressure to up around 1,800-2,500psi. Again a scan tool would be needed there to read that pressure.
Your engine is also a L83. The LC9 is the GEN 4 port fuel injected engine from the previous model trucks. So if your scan tool can't read the truck as a 2014+ engine, possible many of the watched parameters will be wrong in reporting back data.
That's right, my apologies. I forget we are dealing with direct injection. Yeah o2 swapping might be the best bet at the moment.
Yeah, I was worried about mis read data due to that. I just don’t have access to anything to read 14+.
That sounds like my next step. Will report back when I find something.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,335 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
