2017 Chevy Silverado fuel injectors....
Beetown
Checking to see if any Chevy Silverado owners are having same issues. I have a 2017 Silverado Z71 that I bought brand new. Within about the initial 10k miles, my check engine light illuminated & I took it into the local Chevy Dealership (same place I bought it from) & was told 4 of my fuel injectors were bad & had to be replace, so they (Chevy Dealership) replaced under warranty. Then the next 2 went out, then 1 then finally the last one went out several weeks ago. All 8 fuel injectors went out with about 42K miles; within a 2 year span. Other than the bad fuel injectors, I have not had any other truck issues. Maintenance always done at the local Chevy dealership. Any other issues out there?   Please let me know. Thanks.
Thanks for the response. Don't know if buying 'top tier' gas makes a difference? Service Advisor asked me. I to do buy from Chevron, Shell or 76 Mobil. IDK....
87 octane is just fine. I would suspect your usual station has sediment in their tanks.
I've also read on here that people in overly dusty areas get sediment in their fuel tank from the capless fuel necks.
Sent from my SM-J810F using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   5 Members, 0 Anonymous, 1,158 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
