2017 sierra gutless
Olds69442
Sierra with 65,000 kms at about 16,000 I noticed fuel economy was very up and down. But it seems to be worse now.
The truck seems to require more power to move, like something in the front end is holding it back.
If you try and drive on dry grass or gravel it spins the tires.  On wet pavement if you give too much gas the back end kicks out and traction control kicks in.
Just wondering if anyone else has come across this issues and know what is up.  The dealer says no code everything is fine.
Fuel mileage can vary some depending on the season and driving habits. Extended idle times, using remote start, cooler weather etc etc can all play a roll. Mine is always 10-14mpg give or take because it's all shirt trip city mileage.
You'd know if something was dragging on the front. You'd smell the brakes or it would be a pretty noticeable pull when you let off the throttle, like if something in the front diff was an issue. And there would likely be a noise with it too.
Spinning on loose gravel or grass sounds normal. You tire choice may not be ideal or you just aren't as good with your big toe for feathering the throttle. Same with wet pavement, tire choice and your foot are the biggest factors.
The dealer is right though, if you have no codes or any actual faults, they can't really help you when it's still running like normal.
Welcome to the site!
I am guessing by your site name, you are a little bit "older" like myself.
In high school, we judged how quick a car/human was by racing each other, my 73 Vega was pretty fast. Race your neighbor, you will feel much better about your truck!
I think you are experiencing the "hard to depress gas pedal" on your truck, you just have to get used to it, gas mileage will also vary with it getting colder too.
You are driving a very sophisticated vehicle with very powerful computers in control, it does the best it can with temperature, gas, and your driving habits to get the best mileage possible.
Haha, how old do you think I am?
I own several 442's and restore them.
I guess it's too hard to explain my issues, from brand new the truck ran between 8 to 10 litres to 100 kms.  Doing the same drive day after day once I got over 16,000 kms the mileage seemed to jump up as high as 17 litres but time to time no matter the temperature outside.  Over time it keep happening more often, now it's all the time.
At times I could feel the truck change as I was driving, and see the mile go up higher too.
This would be my third brand new GM truck having 2007 and 2010 before so I'm sure to this newer technology.
This truck has been in seven times for repairs and warranty work and the dealer finally got the new code off the truck that kept going off on friday and it have a fuel trim code.
I'm to the point I think it's best to sell it and look at a different auto manufacturer since the 2010 has oil consumption issues and the 2007 had electrical issues.   GM does not build good vehicles and when its shit they dont stand behind repairing there problems.  It's all let's reprogram and see if that works until your warranty runs out and it's the consumers problem.
You should not spin when driving across even wet grass in 2wd. Something is hanging up in the front. Jack it up in there and spin the tires by hand. Dragging brake? Wheel bearing packing it in slowly? Sometime the sliding pins for your calipers will seize up and the brake will be slightly dragging at all times until you pull them out and re-grease or replace them.
How many miles? These new DI engines have a habit of caking the intake plenums and valves with carbon. Much much worse than the LS's port injected engines. If you have a lot of miles it could be due for a walnut blasting or at least an intake cleaning additive. Winter time in Canada now, idle time, colder IAT's, thicker oil viscosity in the trans/diffs lead to more resistance and longer warm up times, winter gas at the pumps, longer warm up times really take a toll on your economy.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,196 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
