fuel consumption
Joelojeda18
I have a 2017 LTZ Silverado 1500 with the 5.3 ecotec engine. I was wondering if this is normal, when I fill up my truck is says it has like 430-450 til empty. But I’m only getting like 350 miles out of a full take of gas. Does anyone know if thats normal or not. The truck only has like 43k miles on the dash.
Are you using the trip odometer to measure or just guessing?
Your fuel mileage will drop if you drive around town and idle a lot. If you're not doing that, I'd be concerned. That range assumes highway mileage, because my 2017 will get that, if I let it use V4 mode (which I don't). I get about 20-21 mpg.
Sent from my SM-J810F using Tapatalk
Don't quote me here but I kinda think it goes off your last 25 or 50 mile avg for the miles to empty.
I drive 95% city miles with my short commute to work everyday. The last time I went up north to the cabin I filled my tank up before leaving. At this point I was getting maybe 12-14mpg so my range said roughly 350-360 miles to empty. My trip there is all freeway and county roads that are 55-60mph. The miles to empty I swear stayed at 350 miles for over 130-140 miles because I was getting 20-22mpg easy on my trip and with that math I could do a little over 500 miles to the tank. The miles to empty range never auto updates and that bugs me alot.
So the next time I filled up the miles to empty said 450+ miles because my avg went way up. Now that it's cold I'm getting about 7-10mpg because I use my remote start and don't care one bit about saving fuel, so my miles to empty is like 230 miles to the tank now if I'm lucky.
Dont forget about winter blend gas as well. Your gas mileage will go down with the winter blend as it is manufactured to evaporate quicker.
There is nothing of note to remember. Winter fuel has 1.5% less BTU content than summer fuel which directly translates to a mere 1.5% drop in economy. 0.3 mpg on a 20 mpg truck. So 19.7 mpg v 20.0 mpg. Unless you're tracking and averaging thousands of miles over dozens of tanks, you wouldn't know it was happening.
Cam gave you the best answer you're going to get. If you put up that screen and watch it awhile you would see if move continuously. It's a projection based on fuel used and miles driven. The remaining fuel is then given a distance based on the current last 25 miles and that projection added or subtracted as the case may be from the first reading to project a current value. The next tank starts on a fresh fill and the projection based on the last 25 mile average from the last tank. Loop  and repeat.
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,424 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
