On 12/31/2019 at 2:20 PM, Vuk said:
I can confirm that this now works, that is, remote start is not bothered by the sensor any more. In short, my audio/tilt/shock sensors and tailgate switch are always emulating the "hood open" condition, except when either the engine is running or accessories are on (in that case the sensors are not active).
One of these days I will modify the schematic to show how to go from the ground output to positive output on the sensors and that should conclude this mod. Anyone who has some experience with wiring relays could do this, if interested.
Would you happen to have a photo how your connected the signal wire to the hood signal. Please
Edited by Gilbert j
Are you able to see the sketched schematic in my first post? That is the one that is still working on my truck for more than two years without issues, just a resistor and diode in parallel to the hood switch. All I have is an occasional false positive from the bed sound switch when it's very windy (even though I have the hard top, the bed is of course not insulated from the environment).
Edited by Vuk
I just went through all of my photos and can't find a photo of the actual physical wires, however, the hood switch has only two wires so if you get a diode and a resistor as shown in my schematic, there's really no bad way to wire it as long as you find the ground out of those two.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
