Newdude posted while I was typing. If they didn’t have very good torque control with their impact driver or if they did the final quarter turn after applying 89 ft lbs, I agree with him they should be replaced.
Yes i would like to buy a Silverado Silverado please.
Then I'm gonna go get the papers, get the papers..... Did GM hire Jimmy Two Times or something to help rename their line????
Based on the service manual picture you posted, the four vertical bolts are single use and the torque specifications appear to be intended to be “torque to yield,” which permanently elongates the bolt. If they were torqued per that specification they should not be reused. However, if they used a properly limited impact device and only torqued them to the initial torque value of 89 ft lbs and did not do the final 70 to 80 degrees of additional rotation, they never yielded the bolts and they could be “reused” and torqued properly. The biggest issue in deciding whether to reuse them likely will be uncertainty over the torque applied by the impact driver.
Register a new accountSign in
