You most likely have a 700R4/4L60 and not a 4L60E. 4L60E had the DRAC and you would swap it for a Box with DIP switches or add them yourself.
4L60E was not used until 93. You have a TV Cable and will need to approach a little different in fixing your issue.
TV cable runs to the throttle body and controls pressure in the transmission for shift points. Should be adjusted using a pressure gauge.
You should have a cable coming off the transmission going to the speedometer for speed.
The DRAC was used as a buffer box to send a digital signal received from the transmission to the ECM/cruise and the dash on new year model trucks.
88 had no DRAC but 89 did. If you received and early 89 its possible to have one. It will look like one of the many combinations below. In the Vans it was behind the dash on the drivers side, on the trucks it was behind the glove box.
Warrperformance offers units with a DIP switch installed if needed. Also a usefull source of information on the units.
https://warrperformance.com/?product=modified-gm-drac-to-adjust-for-different-tires-gear-ratios-tbi
Edited by Mikebtte
I do not have a cable coming off the transmission going to the speedometer nor can we find a DRAC. However one of my mechanic friends even gave me one for possible use. It is definitely not under the glovebox or anywhere under the dash.  That's why we're so befuddled.
That makes since as the 88 had no DRAC, I think you are good on that point. Forgive me as it has been a while, You should have a 2 wire sensor putting out a magnetic pulse the the speedo and a TV cable at the throttle body.
Edited by Mikebtte
Yup,educated me too,been a while also,can't explain my post,cause I didn't see the drac,I assumed it was not on 2 wd ,found more good info on udmodule.com
  • 3 years later...
  • 5 months later...
I have a 97 Tahoe &speedometer is 10 mph fast wheel and tire are factory size and I’ve already changed the VSS  in transmission..
What can I do next to correct this problem?  97  Tahoe 4x4  5.7 Vortec I’m getting doesn’t have drac.
Does anybody know if it has one or not and where it is . Or what else could be causing my speedometer to be 10 mph fast.
  • 4 months later...
This issue ever get solved? I have the same issue with a 1997 GMC Sanoma 4.3l 4L60E. Speedometer is off by 10 MPH at 70 and after driving a while it causes the trans to shift hard and code for p1870 which is a general trans component slippage because the truck isn’t moving as fast as it the computer thinks it is. Could this be a PCM issue or is there a DRAC box?
    250.3k
    chfkief
    chfkief
  • Who's Online   3 Members, 0 Anonymous, 1,488 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
