You most likely have a 700R4/4L60 and not a 4L60E. 4L60E had the DRAC and you would swap it for a Box with DIP switches or add them yourself.
4L60E was not used until 93. You have a TV Cable and will need to approach a little different in fixing your issue.
TV cable runs to the throttle body and controls pressure in the transmission for shift points. Should be adjusted using a pressure gauge.
You should have a cable coming off the transmission going to the speedometer for speed.
The DRAC was used as a buffer box to send a digital signal received from the transmission to the ECM/cruise and the dash on new year model trucks.
88 had no DRAC but 89 did. If you received and early 89 its possible to have one. It will look like one of the many combinations below. In the Vans it was behind the dash on the drivers side, on the trucks it was behind the glove box.
Warrperformance offers units with a DIP switch installed if needed. Also a usefull source of information on the units.
https://warrperformance.com/?product=modified-gm-drac-to-adjust-for-different-tires-gear-ratios-tbi
Edited by Mikebtte
I do not have a cable coming off the transmission going to the speedometer nor can we find a DRAC. However one of my mechanic friends even gave me one for possible use. It is definitely not under the glovebox or anywhere under the dash.  That's why we're so befuddled.
That makes since as the 88 had no DRAC, I think you are good on that point. Forgive me as it has been a while, You should have a 2 wire sensor putting out a magnetic pulse the the speedo and a TV cable at the throttle body.
Edited by Mikebtte
Yup,educated me too,been a while also,can't explain my post,cause I didn't see the drac,I assumed it was not on 2 wd ,found more good info on udmodule.com
  • 3 years later...
  • 5 months later...
I have a 97 Tahoe &speedometer is 10 mph fast wheel and tire are factory size and I’ve already changed the VSS  in transmission..
What can I do next to correct this problem?  97  Tahoe 4x4  5.7 Vortec I’m getting doesn’t have drac.
Does anybody know if it has one or not and where it is . Or what else could be causing my speedometer to be 10 mph fast.
  • 4 months later...
This issue ever get solved? I have the same issue with a 1997 GMC Sanoma 4.3l 4L60E. Speedometer is off by 10 MPH at 70 and after driving a while it causes the trans to shift hard and code for p1870 which is a general trans component slippage because the truck isn’t moving as fast as it the computer thinks it is. Could this be a PCM issue or is there a DRAC box?
    250.3k
    user087
    user087
  • Who's Online   2 Members, 0 Anonymous, 976 Guests (See full list)
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
