Shock/strut or front end component issue?
02Sierra_Mark
Hey folks-  I'm looking for opinions/suggestions on what could be causing a noise coming from the front suspension of my truck.  Truck detail: 2014 Silverado double cab, 5.3 2WD, stock 18 rims with stock size Michelin Defenders (6k miles on the tires).  Truck odo has a little over 60k on original shocks/struts.
When it first got cold here in Houston, near 40 degrees i drove over a dip and noticed a groan noise in the front end area of the truck...didn't hear it again until the next batch of cold weather when i rolled over a speed bump. Now I'm hearing it much more often as I roll over a speed bump or the same dip that is in my company's parking garage.  It really sounds like someone stepping on an old worn mattress...that groan noise as the strings are being compressed.  I think it's my shocks/struts but a buddy told me it seems like it could be suspension parts, like tie rod ends...perhaps needing some lubrication.
What do you all think?  I'd like to get it fixed while I'm off on vacation.  I appreciate the help!
Mark
My bet is sway bar mounts, next time it creaks get some silicone spray or something similar into the two rubber mount that go round the bar up to the frame. If the noise goes away that should be the problem.
Mine does it usually in damp weather or after getting wet & drying out. Haven't got round to sourcing better versions yet.
2014, 5.3, 4x4, work truck
Mine used to creak a lot and rattle, too. Turned out to be one of my shocks up front was shot.
Sent from my SM-G892A using Tapatalk
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
