Went a little offroading today
Dinged up my rocker panel a tiny bit on the passenger side, but my wife in the 2018 LT Z71 with 2" lift crushed one of her side steps...  We were on a part of the trail better suited to lifted Jeeps with 35's and there was one deep hole in a rut, off camber, that we slid into and without offset wheels, the side of the truck and steps hit before the tires did.
I know what my next upgrade is gonna be, after I replace her mangled side step...  haha
Other than that one spot, the trucks did very well...  Lot of fun!  Not what I want to do with these trucks every weekend, but I might see a used Jeep Wrangler in my future...
It's a 48 min video, so it will take YouTube a while to process it into HD, so give it a bit, or just deal with the lower def until it finishes rendering...
What are you driving, again? The 2018 looks nice!
Great video. That trail looks super fun. Wish I had something like that around here!
My wife is in the slightly lifted 2018 LT Z71...  I am in my new LT Trail Boss...
We have a gazillion trails like that in North GA...  National Forests and forest service roads all over the place...
I dinged the rocker panel on mine, just a tiny bit and mainly underneath, you almost can see it unless you really get under there...  Need to install a set of rock sliders...
Thanks for the video......more entertaining than the Ice Road Truckers episode where they were driving beat up POS local trucks on narrow dirt roads on the sides of cliffs on a mountain in India.
Nothing like that here, back roads and ones skirting the Potomac and Shenandoah are a piece of cake compared to the ones in the video. As desolate, but not as demanding, desperate or scary - worst that ever happened was when my father-in-law freaked with a WWII flashback to a battle in the Ardennes.
No way I'd have the balls to take anything I owned on that road...........but, definitely a candidate for a fun trip in a rental Jeep with full coverage.
Yeah, I won't make a habit of getting in that rough with new trucks.  I have had the Trail Boss for like 3 weeks, and my Wife's truck is my 2018, so still almost new...  Not things we want to bash up.
I was on that tricky part last year and don't remember it being that bad. But I think that the Jeeps have really dug that rut up over the past year, it's twice as deep as I remember it.  It was really just that one hole...  I should go back with a bunch of rocks and throw them into that hole, to build it up about 1.5 feet and it would be easy at that point.  The trucks could get through it now, but not without scraping either paint or running boards...  Filling in the hole with rocks would solve that...
I was like this isn't so bad and then... CRUNCH...  woops.  LOL
I can buff the couple scuffs in the clear coat that I took, but I will have to replace her side step.  The mounts are pretty mangled, not sure I can get them straightened with a hammer or not.  But at $300 for the set, not the end of the world if I have to replace them...
My buddy got out of the truck and took a couple videos with his cell phone, so I will try to post those later.
Jeep with a winch helped pull the truck's front end away from that clay wall... Didn't want to scrape the crap out of the bumper or fender, and that tension on the winch rope kept it from grinding along that wall.
The TrailBoss has GoodYear UltraTerrains and they seems to have better grip in the mud... The RidgeGrapplers on the second truck seems a little better on rocks and stuff...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
