40" LED Light Bar in Grill
Interested. Lets see the mounting pics and finished product.  Very top opening or second one? Thanks.
Well, my brackets look like shit and I'm a shitty welder bit it is strong and rigid. The grill can be removed without removing the light bar. It's rough wired and I'll run it for a couple weeks to see if it needs any adjustment. It was a pain in the ass working alone and trying to fab in that tight space with the grill on.
Sent from my SM-G950U using Tapatalk
Nice work man. Thanks for sharing.
Sent from the demons in my head
How do you have it switched in the cab? What type of switch and where did you mount it?
It comes with a full wiring harness and rocker switch. I have not routed and mounted it yet. It's currently just strung into the cap through the window. I'll route it through the grommet in the firewall and find a place to mount the switch next weekend.
Here is the light I got.
https://www.roughcountry.com/40-inch-curved-led-light-bar-72940blkdrl.html
20 hours ago, 2016HD said:
Would it not have fit behind the grill without cutting it out?
It would have fit but I felt that it blocked too much of the light.  No use buying a light and putting something in front of it..
17 hours ago, slj2008 said:
look's good , What about the open space on both side of the bar ??
It's not big enough that I am overly eager to fill it.. I did retain a piece of the grill that I removed that I may fill the gap with.. I would use the threaded mount at the end of the fixture to mount the extension/filler.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
