Help with Suspension Level/Lift for 2018 Silverado
Wilkens
New member here. I'm seeking advice on how best to level my 2018 Silverado 1500 Z71 crew cab. I would like to level the truck or perhaps maintain a slight forward rake, while providing enough room for 33 inch tires (I'm thinking 275 70r18s on the stock 18 inch wheels). I'm also interested in improving offroad performance (not merely a cosmetic modification). This is my daily driver, so I'm looking for an approach that will best serve as a jack of all trades, to the degree such a task can be achieved. I am more concerned with performance both on and off road as well as durability and ease of maintenance more than I am with price.
After some initial online research I've identified a couple of potential options, but I wanted to seek the advice of the pros on this forum. One thought would be to use Falcon's new sport suspension leveling system which I believe raises the front end up to 2.25 inches and uses the stock coils. Alternatively, if it would be beneficial I could go with coilovers, though I don't know which would best serve my objectives (Fox? King?). I am also under the impression that the stamped steel upper control arms that come on my model are less than optimal in a leveled or lifted truck, and as a result might be well served by aftermarket UCAs. Here again though I'm not sure which would be best, if this is a necessary modification. Finally, I'm wondering if this project can be achieved without substantial permanent modification to the vehicle such as cutting and trimming. I would like to avoid excessive tinkering if I can. Any suggestions on the build would be very much appreciated. Thanks so much in advance.
If it were my truck and I plan on going off road with 33" tires I would just do a 4" lift.
2.25" it will probably  rub when you bottom it out.
For more of a performance lift coilovers rule. Not cheap though. This is what I would do if I wanted a small performance type lift.
The truck pictured has a 4" BDS lift with 33x12.50x22 on 22x12 wheels
Go to
www.customwheeloffset.com
for more pics
1bf0d54bc0797aedea19ab7e19298d3a.jpg8b67b94e891fadf393f6604ee9d4ab58.jpge7be0bc58c628678a821b9940f9ec5b1.jpg
Sent from my Pixel 3 using Tapatalk
Adjustable Bilstein shocks in the front will give you enough room for 33" tires. It will also keep some rake.  Add Bilstein shocks to the rear as well.  This would probably be fine for some off road use as a daily driver, assuming you aren't talking about extreme use.  Hard to say though as it's not clear how much off road use the truck would get.
2.25" level only is too much unless you replace the rear blocks with larger ones or add a leaf to the spring pack to give the back some lift to maintain some rake.
I wouldn't replace control arms unless you observe rubbing with either setup. As mentioned, a full 4" lift would also work.  Not sure that qualifies as too much tinkering though.
Go to
for more pics
Thanks for the suggestions. This looks like a great setup, but if possible I would like to go with something slightly more conservative, i.e. less tinkering with the vehicle. With that in mind, I was thinking about mimicking a setup like this: https://www.silveradosierra.com/suspension/2016-cognito-fox-coilover-leveling-kit-t565250.html OR https://www.silveradosierra.com/suspension/fox-2-5-resi-coilovers-with-cognito-uca-s-installed-t698470.html
The price on this Camburg setup is a bit steep, but doable if it were the best way to go: https://camburg.com/shop/suspension/camburg-chevygmc-1500-2wd4wd-07-18-fox-2-5-factory-dsc-kit/
Alternatively, Falcon Shocks offers this system which is more affordable and to my understanding provides more lift and is generally a step above Bilstein 5100s. It may also be more durable than having remote reservoirs, but I really have no idea, that was just the opinion of one shop I spoke with: https://www.falconshocks.com/chevy-gmc-1500
Any opinions on something like this would be very much appreciated. You raise a good point about bottoming out, that's something I want to avoid. However, I would like to keep it under 4 inches if I can. If that means I would be better served by using a slightly smaller tire I'm willing to consider that.
Thanks for the suggestions. I don't need to maintain some rake, I would consider it if it were feasibly possible though. A flat level would also be acceptable to me. Along with the options I saw posted above, I am also considering the Falcon Shocks system which is similar to the Bilsteins but which to my understanding provide slightly more lift and are maybe a step up from there. I think the product is fairly new so any thoughts on it and others are welcome: https://www.falconshocks.com/chevy-gmc-1500
Bilstein 5100s, deaver mini-pack,  rear block removed and 275/70/18 falken Wildpeak at3ws. Rubbed some at full lock in reverse, after a couple thousand miles, no rub. No rubbing offroad either.
Your truck looks great. That's a very similar look to what I'm going for. Don't the Bilstein 5100s provide up to 1.85" lift in the front? If that is correct, I'm optimistic that I wouldn't have rubbing issues running those same Falken 275/70r18s with an option that provided 2.25"in the front (Falcon Sport Leveling) or 2.5" (King 2.5 coilovers).
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
