06 only shifting in manual
Hello got an 06 1500 z71 5.3 roughly 175k on it.  All the sudden it will not shift out of first if I put it in the D position.  However if I place it into 1 I can then shift to 2 then 3 and so forth any ideas?
thanks
Once on 2nd, if you put it in D, will it shift up? If yes, 1-2 accumulator is shot. If not, oil pump may be failing requiring higher rpms to shift. Try a WOT test.
Also, if one of the engine sensors (ie tps), this could be giving bad data to the computer preventing it from calculating shift points.
read codes from the tcm.  you need to use a more advanced code reader than the basic, cheap ones.  some parts stores will have one that will do the job, but I would suggest phoning ahead and checking...
    ballencd
    ballencd
  • Who's Online   4 Members, 0 Anonymous, 444 Guests (See full list)
