I have a 20 Sierra Elevation with a 3.5" Rough Country Lift. I swapped my factory wheels with a co-worker for some 20x10 with a -24 offset. He has some "what looks small" 285/55 R 20 tires on it know. What tire size do you recommend. My main question is what is the largest tire size I can run
look at thread below yours with 3' RC lift by chris walker
Depends on do u want taller or wider..?  On chevys they go to 295/60/20 =34x11 or 305/55/20 =33.5-12.50 both these sizes are popular on here. Some fit 35s but trim.  So on yours they use a little smaller with the wheel well shape. I'd measure it and see is a 295 60 would fit. That gives u a little width plus the heigth.
Edited by Flatblack83
14 hours ago, Flatblack83 said:
Depends on do u want taller or wider..? Go to 295/60/20 =34x11 or 305/55/20 =33.5-12.50 both these sizes are popular on here.
I have 295 60s with a 3 inch on stock 20s, no rub.
I was looking into 295/60R 20 but i dont have factory wheels. My wheels have a -24mm offset. I think I will buy a set of that size and try them. They are barely wider than what I have but taller than what I have now. The hight is what I'm  after. The width is what is worried about.
3 minutes ago, Flatblack83 said:
Take a look at the custom offsets gallery,  lots of wheel n tire combos on there.
I looked at them. They have a lot for the previous gen trucks but they dont have a lot for this gen. If they do, I can't find it. I traded my factory wheels for these with my co-worker. I can trade back with no problem, but I really like the way the wheels look, but the tires look to small
There is a few GMC 1500s, not sure on your package tho.. Most with a 20x10 with a 3-3.5 lift have 33-12.50-20 or 305 55 20.  The 6 plus inche Lift most are 35-12.50.
Turn the wheels and measure how much room you have, that will give you a basic measurement on how  tall/wide you wanna go. An inch taller looks like it would help you a ton. Remember an inch taller is a 1/2 inch bigger all the way around...really isn't much.
I've got the same truck just different color. It's getting the 3.5 rc lift today..  what size tire did you end up going with? I've got 33/12.5 r20's to put on it but thinking I have to buy different rims. Kind of sad cause I hate to get rid of my ballistics rims..
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
