2015 Silverado tail lamp connector question.
Hello, I'm wondering if anyone knows where I can find some connectors that would plug into the tail lamp wire connectors on my 15 Silverado.
I'm talking about the connectors down on the rear junction box by the spare tire, looking for the ones that plug into the PT2274 and PT1391. They would look something like a PT1389 (PT1389 might be for PT1391).
Any info would be great, Thanks,
Are you looking for the harness that the bulbs plug into? I replaced both of mine with dealer parts for like $25 each. They come complete plug and play no splicing required. If you're looking for the chassis harness side your best bet will be dealer as well.
Sent from my SM-N975U using Tapatalk
I'm looking for the pigtails on the chassis side and pigtails that would plug into them. I realize they plug directly into the junction box but I've seen actual male pigtails for them before. I just can't remember where. I'll try the dealer though.
10 hours ago, tbarn said:
I come up with P/N's 22869169  23141278 for complete harnesses  assemblies.
P/N 19330152 for plug with leads.
https://www.gmpartscenter.net/oem-parts/gm-connector-kit-19330152
Thanks for this, I'm looking for the other end as well. The plug these would plug into. I know its built into the junction block at the rear but I'm pretty sure I've seen a stand alone plug for them before.
There is no other side connector. All power, ground, signals, etc come into the block on connector X1. Then are distributed out through connectors X2 thru X6.
Unless you mean the block itself.
P/N 23208491 W/ backup cam
P/N 23208492 W/O back up cam
I was trying to make a custom harness, I went a different route on the trailer connector. thanks though guys
