BFG KO2 - 3-Peak vs. DT
Icutmetl
I am interested in replacing the 265/60R20 mall-terrains on my 2018 All-Terrain HD Duramax with 275/65R20, and the KO2 is one of the tires I’m interested in. I’m aware of the myriad of options; but for the sake of this topic, I’m only concerned with the KO2.
I know and understand the differences between the two specs; I’m also aware of the fact that only the DT version carries a mileage warranty.
My truck is not a daily driver; it’s well-maintained, and  I don’t drive overly aggressive (heavy on throttle, tire spin, etc). I’ve got a little over 15k since new last year, and the factory bologna rinds still look new. I live in Ohio and travel during the winter for snowmobiling trips to areas like the UP of Michigan and out west, sometimes pulling enclosed trailers. Stability & snow performance is of strong consideration for me, along with the all-terrain tread. Getting good mileage out of them is important, but maybe not MOST important.
My question is this; considering the above information, would you prefer the 3-peak rated KO2? I’m leaning that way, as I feel it fits my overall needs better, but will be disappointed if I spend $300/tire and they need replaced in say 30k miles.
Thanks!!
Thanks!!
I say 3 peak for a half ton. I would only go DT on 3/4 ton or a truck that gets a-lot of miles.
I have BFG K02 3 peak on my 2018. They prob have 20 - 25k on them. I ran them on my 1997 k1500 for 15k miles and did some towing. They are showing wear but are 5 years old this year. Still probably 40% tread left? noticeably less tread in center of tire, I keep pressures at 48 psi cold, could probably reduce that down to 40 - 42.
I see you have 2500HD in your signature.
If you have the gas, you could go either 3 peak or DT.
If you have the Duramax, get the DT due to the additional wight and more importantly, tire wearing torque!
I appreciate your guys’ replies. I tell ya what; if the KO2 had both a mileage warranty as well as the 3-peak rating (like the Grabber ATX does), I’m sure it would be a no brainer for quite a few people.
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
