Trouble with adding onto Bose system?
Hi everyone, brand new here.
looking for some insight into the stock Bose system for my 2017 Sierra Denali. I’ve heard there are 2 types of Bose system a “standard” and a “luxury”. Heard that a few GM models (one being the Denali) has the “luxury”Bose system. I’ve seen that the luxury system is all controlled by the amp which has Crossovers and tuning programmed specifically for this sound system.
Here’s what I’ve done that led me to this research.
Added a 4 channel amplifier for the door speakers and a monoblock for my subwoofers. I integrated this with a “loop back harness” made by LLJ customs. Factory plug and play harness that takes signal from the Bose amp, send speaker inputs to an audiocontrol LC7i to give me 3 sets of rca outs (2 for 4 channel and 1 for mono) and also gives me speaker wires to hook up to the 4 channel spliced back into the factory plug in to door speakers. The harness also links the factory tweeters and subwoofer back in which are still feeding from the Bose factory amp.
I’m not too pleased with the sound. I noticed that sitting in each seat around the truck sounds completely different. Front speakers seem full range with mids and highs while rear speakers sound almost like tweeters just more high range. After some tuning and testing I also checked the subwoofers out for sound. Sounds good however really low end drops out. Seems anything below roughly 32 hz does not play through the subwoofers.
at this point I plugged the factory harness back in to sound check the factory. Funny thing is, just about the same thing. Different sound from every seat.
my thought is that Bose somehow is factory tuned this way possibly in an attempt to optimize sound for the driver? Am I onto something with this in also thinking I can’t play very low frequencies because the Bose system has filtered it out in an attempt to protect the factory speakers or subwoofer?
Looking for any information on how the Bose system works. If my hunch is right I think the only way to improve at this point would be to switch to an aftermarket head unit and cut the Bose amp out completely.
Thanks in advance
Use the fronts(whatever speaker wires have full range) across the channels you need full range sound going into the lc7i. It should work just fine. The signal/ voltage is powerful enough with my non bose I'd assume its even better with your bose. Give it a shot and post the results. The rear channels suck as you've found just that way from the factory...
Sent from my LG-G710 using Tapatalk
17 minutes ago, Snowcamo said:
You run the front wires into one input of the lc7i and jumper wire from there
That’s what this harness does. The LC7i has 3 sets of speaker signal inputs. Output 3 rcas to sub amp is supplied a signal from input 2 which is the front door speaker signal. Output 2 to 4 channel. Input 1 is from the rear speakers however there is a feature for “channel summing” on the lc7i which uses input 2 and merges it with input 1 and puts that merged signal out on output1. Essentially with the lc7i I’m able to use the front speaker input signals to produce all 3 output signals. I’m worried that the “full range” signal is not actually full range and filtering out the extreme lows.
my other thought is that the factory tuning is the cause of the difference in sound from every speaker because it sounds roughly the same (just less powerful) when I take the harness out of the equation and plug back into stock.
Ok so in short if you only use the front channels connected to ch2 and ch3 (not using the rear)all the speakers still sound the same? Makes me wonder if the amp is even bypassed. Are you using aftermarket speakers? Also you can open the lc7i and turn off all the dip switches btw. I do not have this issue with mine. Then again mine isn't bose.
Yes, that’s what I’m looking for more clarification on. The Bose amp is bypassed for only the front and rear door speakers. The factory tweets and factory subwoofer are still in tact and powered by the Bose amp.
the Bose system is very different than stock setups and Bose/gm make the detailed info tough to find. This is why I’m reaching out, I’m hoping there may be a GM tech or someone heavy into audio that ya dealt with this before that may have info and or schematics on what’s going on behind the scenes with the Bose setup.
Gotcha. Makes zero sense if your using aftermarket speakers in the doors. There isn't an inline bass blocker or anything that would cause issues. Just doesn't add up weather its different or not what ever the front sends out the amp lc7i should put out to the amps then speakers.
4 minutes ago, Snowcamo said:
You might just endup running speaker wire from the amp to the doorsemoji848.png
From my understanding the Bose is different in that the head unit is not sending the signal to the speakers. It sends signal to the Bose amp which has factory tuning/crossovers/filters. Being that the actual speaker signal comes from the amp, for this type of setup you have to use the Bose amp outputs to go into the lc7i there is no speaker level signal available before the Bose amp. Being that this is the only signal I can use I’m at the mercy of whatever the Bose amp is putting out for a signal. So whatever Bose has decided to filter and tune out is the signal I’m getting.
Agreed, but if your bypassing as in not trying to send the sig back to the bose from your aftermarket amp (then speakers), the doors and sub should all receive the frequency range of the front doors. There lies my quarrel. I think we both agree something isn't the way it should be. Have you tried taking a speaker and checking directly from the aftermarket amp?
Correct that’s how the harness works. The wires from my 4 channel amp do not go back to the Bose amp they go directly to the speakers. The Bose amp is essentially the head unit in this case. Picture the Bose amp as the original source of output which in most cases is the head unit. Except this head unit (the Bose amp) is already programmed with crossovers and filters that are not adjustable. I am indeed taking a “full range” from the front speakers. I believe the issue is that the full range is limited by these internal settings. Bose idea of a full range seems to bottom out below 32ish hertz. Again I think this is a protection they build in as an attempt to protect the stock woofer.
Yeah i could see that. I mean most door speakers dont play that low and that tiny bose sub can't hang with the lows man... It'd sound like crap trying to hit 20hz. Lol
Edit: word change
4 hours ago, Snowcamo said:
Try keeping the volume under half of the max. The turn up the gain on the lc7i and amp. Does it still sound the same? Here's a thread on a diff forum post 18 is a bit informative.
https://www.corvetteforum.com/forums/c7-general-discussion/4329173-c7-stingray-bose-stereo-does-not-sound-good-2.html
Good info, thanks for the share. Unfortunately this further confirms my theory of the Bose system having its own tuning to optimize the setup, or as some say, "compensate for their crappy speakers". I'll have to test out low volume vs high volume. So far no matter the volume I haven't noticed any real differences and I've done a lot of playing around. Either way even if the sound or range is better at lower volumes, not sure there's much that can be done as a work around. To keep volume on the head unit below half, the gains would need to be cranked and that may dirty up the signal.
Crappy situation, I was actually somewhat high on the bose stock system as in my last truck (2012 silverado ltz with bose) I had almost this same setup I've just installed except different subs and no lc7i. I had a more basic head unit that I opted to switch out to aftermarket since I wasn't losing much in features and integration. Completely took the bose amp and all the logic out and had rca outs off the aftermarket head unit. The speakers sounded great as did the overall system. Ran it this was for almost 7 years and loved it. Figured I'd be able to accomplish the same quality without going aftermarket on the head unit in this truck but was unaware of how the bose operates. I thought what you've been thinking. Front speakers will give me a full range signal without question. Just need a nice LOC to keep a clean signal to send to my amps and I'll be all set. Oh how wrong I was.
Not sure if I'm just being picky because I'm used to a better sounding aftermarket sound system or what to really expect. I'm sure most average people wouldn't even notice the extreme low end bass dropping out as these frequencies only come up in certain songs. I've been into car audio since around 2004 so I guess my ears may be a little pickier than someone who has stuck to stock and not gone aftermarket their entire (driving) life.
Actually I have been screaming DSP as it was told to me by very knowledgeable forum members who are no more or just stopped posting. In short the signal does need to be boosted and cleaned up. On the base model you can get away with a LOC just barely and have a somewhat decent signal. For the guy on a budget(i.e. me lol) its a go. That being said
You have every right to be particular to the sound you are after and I wouldn't take less. It really sucks these factory radios are crap. Because these trucks are the most sought after these days. You'd think they would of stepped up the game the base factory plays as low as it comes.
The thing folks who no little about car audio dont realize is theres no way your gonna get a super clean/ powerful signal outta that little module thats smaller then a mans wallet. Just aint gonna happen. Not enough goin on inside that little turd to make music really sound decent. Anhoo. Theres a forum member named (NASTY) I havent seen him post here in a while. He will be the dude to talk to fore sure as he's tried every dang thing with these trucks. He is or was a member of Stevemadedesigns.com id pm him over there and get the real deal. You might have to (wait for it...) But he can help.
Theres other members here with bose. Maybe they will come out of hybernation/ lurking and say what they have and if it works for them.
Im all for low bass. So more power to ya getting squared away?
    KirbyCo
    KirbyCo
  • Who's Online   7 Members, 0 Anonymous, 1,216 Guests (See full list)
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
