2019 Trailboss 5.3l 8spd issues
Started truck yesterday, idled down and put into gear. It clunked into drive, kind of like when you put it into geared when revving a bit.
Took off like I was in 2nd or 3rd and wouldn’t shift. Pulled over shut truck off and restarted and it works fine. All day yesterday running errands if it was parked more than 5 mins it would do it again. Shut off and restart and it’s normal - frustrating.
Anyone else? What was the cause/remedy?
It goes to the dealer soon for the brake recall issue that I have been dealing with since mid-December as well as regular maintenance so want to have back up info to make sure they address it.
What was the build date of yur truck, Asking cuz after like 3/15/19 they put Moble1 fluid in the transmissions and Dexron IV and people with the Dexron are having issues, Although my truck the build is 7/13/19 and it was cold without letting it warm up a little it shifted hard from 1rst to 2nd but never an issues after that......
Mine is a May build. Seems to me like a computer issue the way it acts. Going in Wednesday- will post update.
Sounds like it's just a GM 8 speed doing GM 8 speed things. Horrible transmission in my opinion.
Hoping for the best. I was happy with it so hopefully it’s part of the computer problems that have been happening on my truck.
Well it is now stuck in 2nd or 3rd gear at all times. F@“&
On top of that had a different brake issue while driving today. Instead of the usual losing the power assist (recall programming issue) the brakes felt super spongey and easy to push. There was no brakes or full lock up. Nothing in between.
So driving 80km/hr at 3500rpm with sketchy brakes in a snow storm all the way home was nice.
It goes in tomorrow for a list of work.
Was just told it is catastrophic failure and that the transmission needs to be replaced.
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
    • I think the ship has sailed on the fuel injection type - everything is getting direct now.  Does it help with mpg?  Not really and nobody buying a HD truck really cares anyway.  But that is what it is at this point.  Piston rings is something they may well adjust over time to get them right.
