Anyone know of replacement horns that will plug into the stock wire harness? Looks like they jump from 1 horn to the other, and each has a different plug...
  • 5 months later...
Did you find any solution to this? Factory horn sounds weak.
Unfortunately, I have not.  Factory horn is a joke.  Sounds like a sick calf.
  • Haha 1
Yeah I've been hoping for a decent replacement plug and play horn for almost a year now.... forget about it until I use it.... shameful!
22 hours ago, Hagar68 said:
I just added 2 additional horns.  Relay tapped in to original horn wire.  Mounted new horns on firewall over engine.
Would be great if you could post some pics.
TOMATO:   here are pix of my horn additions, 2020 gmc double cab 2500 gas:
The silver bolt next to the yellow wire in 2nd picture is an existing bolt on a bracket extending towards the engine on the rear inboard corner of the battery.   Used a scrap 1"x1"x1/4" piece of aluminum angle and fastened the horn assembly to that one existing bolt.
These are just Auto zone/Adv auto horns off the rack (they come this color).  Nothing exotic but a very different tone (very loud beep) that makes the combination of the 4 horns more noticeable while not being a discord.     I looked on Ebay for those 4 horn sets that used to come on cadilacs but they were pricey.
I measured amps, looked at fuses, and decided I HAD to add a relay which just gets the hot right off the battery.   The relay delay is not noticeable.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
