I can’t find the parts numbers for these, any one know what they are, I know there’s 2 different packages each with different models for ior and ios
Just a heads up - a simple google search showed the three results below.
PART # SSICRE14 - Powered Subwoofer Upgrade System for 2014 - 2018 Chevrolet Silverado / GMC Sierra 1500 Crew Cab.  Also compatible with 2015 - 2018 Chevrolet Silverado / GMC Sierra Crew Cab 2500/3500.
https://www.kicker.com/SSICRE14
PART # SSIEXT14 - Powered Subwoofer Upgrade System for 2014 - 2019 Chevrolet Silverado / GMC Sierra 1500 Double Cab.  Also compatible with 2015 - 2019 Chevrolet Silverado / GMC Sierra Double Cab 2500/3500.  Will work in 2019 1500 Silverado LD and 2019 Sierra Limited (old body style) only.
https://www.kicker.com/SSIEXT14
2019 Sierra 1500 MultiPro Tailgate Audio System by KICKER®
Part # 19417163 Manufacturer : Genuine GM
https://www.shopchevyparts.com/electronics/2019-sierra-1500-multipro-tailgate-audio-system-kickerreg/19417163-p-92303047.html
https://www.shopchevyparts.com/next-gen-silverado-1500/electronics-c-26_4692_4729_4743.html
Two are DSP with amp for non-Bose.
RPO IOS (mid-level infotainment):
19417166
RPO IOR (base model):
19417165
Sub-only for any system:
19417164
1 hour ago, Damronjr said:
What do you think of it?
Well, at first I was disappointed. I switched the amp switches to 1-5 up, 6 down and it got much better, but not great. The Kicker FlexTune app is ok for fine tuning but the eq on the head unit has a bigger impact on the sound. Once I turned that up a little from zero, I’m actually happy with it.
I spent just under $1,000 for the sub and speaker amp, and I could definitely do all that plus upgrade the speakers doing it myself with aftermarket gear. The convenience of a factory plug and play setup is nice, but the performance could be better for the price or the price could be lower for the performance. If I was less capable, it would be completely worth the cost, but I can run my own power wire and wiring harness adapter, so I think I could have done better with the $1,000
Where are these dips switches everyone talks about there’s none on either side of this amp
You have to remove the amp from the box. It's just 4 short Phillips-head screws. Underneath the amp is a rubber plug covering the switches
I installed the 19417165 two amp system in my new 2022 TB Ltd.  I am very happy with the sub but not impressed with the second amp for the front speakers.  Also I have to adjust the balance over to about halfway to the left to equal out the left and right front speakers.  Did anyone else have to adjust the balance to get the fronts equal volume ?
Hey Nick, I have a 2022 TB LT and installed the kit for Bose and I'm really impressed with it! Couple of questions, did you also install a bass knob? And where did you connect your amp input leads?
Edited by smooth68
I did install the control knob.  Goes right into the amp.  I can control the sub With the Kicker Flextune app also but only because I have the Kicker add on with the second amp.  I have the non-bose.  I wish I would have bought the Bose system.  I'm installing new speakers next week also.Screenshot_20220115-191036.thumb.png.90fe5f9a5007412edbc15a4ae2f407ea.png
Oh cool…and I wasn’t thinking I guess but since you don’t have the factory sub you can’t connect to those leads, which is what I did.  Not sure if the non-Bose kit connects to the right front leads but the seems like it would want a signal from both channels. The flextime app might provide some decent options.
    btm
    btm
  • Who's Online   5 Members, 0 Anonymous, 1,465 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
