Tounge and knuckle
The ball joint stud is different for the aluminum knuckles. I would imagine if you replaced the upper control arm, lower ball joint, maybe outer tie rod and maybe the brake hose you should be fine. Moral of the story is the taper is slightly different from steel to aluminum. You'd have to check part number differences. Brakes hose brackets can vary from one control arm to another.
Sent from my SM-G988U using Tapatalk
