Kicker system
I purchased a 2020 GMC Sierra 2500 Denali. It did not come with the multi pro kicker system so I purchased it separately and installed it with no problems. After about a month my daughter tried to set the navigation on my radio and it reset my radio to factory defaults and now my kicker system will not work. It will not stay powered on and connect. Please help.
I’d have to guess that those issues are coincidental and unrelated.
Did you double check all the wiring and any related fuses?
Also try unpairing your phone, power cycle both and see if it will re-pair with phone.
Yes I did double check all fuses. I disconnected the negative terminal for 30 minutes with no luck. I let the truck sit for 24 hours and this morning it works perfect. It makes no sense but I’m glad it works again.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
