Bumper LEDs
Been a while since I’ve gotten to update my rig. But I’m excited to share the experience as I have had more time to tinker. Recently I added some LEDs to my bumpers. So far the fronts are good to go. The rears are mounted but I need another wiring harness. Too easy. Enjoy ??
19’ Silverado 3500
Road Armor Vaquero Front/Rear bumpers
Banks Derringer/iDash
Banks CAI
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
