Trying to figure out this noise
I'm trying to figure out this noise, but I can't really describe it. I'm not sure if its normal or not. The noise only occurs when I turn the truck off. It last for 2 to 3 seconds and its coming from the driver side of the engine bay. If I had to guess, it would be a vacuum leak noise, but its not a whistling noise. The truck isn't throwing any codes and is running perfectly fine. Does anyone have any idea of what it could be? I also tried searching for it on the forum, but I couldn't find anything on it.
Probably relieving the case pressure
I tried listening for the noise inside the engine bay and had someone else turn the truck off, but I couldn't hear it then. Its only noticeable from inside the cabin. Could it be the HVAC system releasing pressure? When I turn the truck off, the HVAC unit is always turned off.
Believe it is the fuel pump/system releasing pressure in the lines, it makes a "clicking/thunk" sound around 3 times (trying to remember).
You should also hear the system prime itself when you first open your drivers door.
That would make sense then and I know when the door opens that the fuel pump is priming itself. Thanks for your help.
You are very welcome.
All things that would be nice to know if there were still "salespeople" on the lots that actually knew how the trucks worked from top to bottom, those days are coming to an end.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
