Can you hear it leaking and creating the exhaust leak or tick?
Having the condensation leak out there isn't uncommon. The bolts could be loose or there is a rust/corrosion built up between the two pieces of exhaust pipe. I can't remember if there is a exhaust donut seal there or if it's just a metal to metal seal. They do make an exhaust paste that can be applied to those type of connections too.
That’s normal. Check your manifolds you most likely have broken manifold bolts. Like 95% sure you do.
    DroppingDiesel
    DroppingDiesel
  • Who's Online   3 Members, 0 Anonymous, 951 Guests (See full list)
