Trouble with headlights...
I would check the dimmer portion of the multi purpose switch under the turn signal lever. If you hold it with the light switch on, do you get any lights? That happened to mine. They are a bit of a pain to replace.
Also could be the actual light switch, which I've also had to replace once on my 91 s10
