2002 Silverado 4X4 Regular Cab Z71 5.3
WHAT is this squeaking noise?  Anyone?
Truck has a minor soft low pitch  sometimes intermittent muted  squeaking noise coming from somewhere near the ash tray area - or near the airbag key/light on dash - or someplace nearby.
Yes, have removed ash tray - that's not it.
Could be coming from heater area.
Noise does not fluctuate with heater fan.  Heater fan Off.  Still noise. Heater fan on any speed - noise is the exactly the  same.  No change is pitch or sound on any fan speed.
Turn the engine off - then key in ON position - still squeaking noise.
Hvac? I have a ticking or popping noise that I'm trying to figure out under my dash. ticks and pops weather the fan is on or off. Only does it when i mess with the climate levers heat or cold.
Edited by echobyte
I have a 2002 myself and have been doing a lot of work to it recently.  any chance the sound disapears when the guage/radio trim/bezel is off?
I found it most interesting that GM put a micro bead of rtv like substance around the inside edges of the bezel to eliminate squeaking and vibrations.  I wonder if that's deteriorated or fallen off on your car and is the cause of a squeak that you hear.
Thank you for the answers.  Note that the sound is sporadic.
Sometimes no issues. No squeaking.
Sometimes the sound all day or squeak one trip.
Well.  It's been  a month now.
And no squeak.
Sounds like your noise may be the blend door actuator.
I chased a squeaking sound for more than 10 years on my 2002, that I though was coming from behind the gauges in the dash.  I ripped that thing apart stuffing foam and felt everywhere.  It turned out to be excessive slop in the lower steering column bearing.  Added a worm drive clamp for $.90 and fixed it, per the link below.
https://www.refugeforums.com/threads/chevy-truck-steering-clunking-noise-easy-5-00-fix.1007043/
  • 3 months later...
And no squeak.
Had noise on and off for about 4 months. Last year.
So far, it's been gone for about 6 months.
Well, that dash sound was weird.
I did take truck to local mechanic and he heard the noise.  As if continued I was going to have this looked at further. It was a muted sqeaky noise.
It was there for weeks at a time.  Then would go away.  Then come back.  Seemed to come from just above the ash try or thereabout.  It did not sound like anything coming from the heater/fan.  But who knows.
It is gone now for quite awhile.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,238 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
