2002 Silverado 4X4 Regular Cab Z71 5.3
WHAT is this squeaking noise?  Anyone?
Truck has a minor soft low pitch  sometimes intermittent muted  squeaking noise coming from somewhere near the ash tray area - or near the airbag key/light on dash - or someplace nearby.
Yes, have removed ash tray - that's not it.
Could be coming from heater area.
Noise does not fluctuate with heater fan.  Heater fan Off.  Still noise. Heater fan on any speed - noise is the exactly the  same.  No change is pitch or sound on any fan speed.
Turn the engine off - then key in ON position - still squeaking noise.
Hvac? I have a ticking or popping noise that I'm trying to figure out under my dash. ticks and pops weather the fan is on or off. Only does it when i mess with the climate levers heat or cold.
Edited by echobyte
I have a 2002 myself and have been doing a lot of work to it recently.  any chance the sound disapears when the guage/radio trim/bezel is off?
I found it most interesting that GM put a micro bead of rtv like substance around the inside edges of the bezel to eliminate squeaking and vibrations.  I wonder if that's deteriorated or fallen off on your car and is the cause of a squeak that you hear.
Thank you for the answers.  Note that the sound is sporadic.
Sometimes no issues. No squeaking.
Sometimes the sound all day or squeak one trip.
  • 1 month later...
Well.  It's been  a month now.
And no squeak.
Sounds like your noise may be the blend door actuator.
I chased a squeaking sound for more than 10 years on my 2002, that I though was coming from behind the gauges in the dash.  I ripped that thing apart stuffing foam and felt everywhere.  It turned out to be excessive slop in the lower steering column bearing.  Added a worm drive clamp for $.90 and fixed it, per the link below.
https://www.refugeforums.com/threads/chevy-truck-steering-clunking-noise-easy-5-00-fix.1007043/
  • 3 months later...
And no squeak.
Had noise on and off for about 4 months. Last year.
So far, it's been gone for about 6 months.
  • 1 month later...
Well, that dash sound was weird.
I did take truck to local mechanic and he heard the noise.  As if continued I was going to have this looked at further. It was a muted sqeaky noise.
It was there for weeks at a time.  Then would go away.  Then come back.  Seemed to come from just above the ash try or thereabout.  It did not sound like anything coming from the heater/fan.  But who knows.
It is gone now for quite awhile.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
