On 4/7/2020 at 12:11 PM, jlong1984 said:
It appears Carbon Black Metallic is a Fort Wayne only color, no matter the trim. All 45 trucks near my zip code are 1 VIN.
On 4/7/2020 at 12:23 PM, newdude said:
Front axles.
GM FRONT AXLE
AAM FRONT AXLE
Can you change out the Noisey Aam (gu4) and put in a gm(gu5) front axle?
10 hours ago, SeanChev said:
Can you change out the noisy AAM (gu4) and put in a gm (gu5) front axle with same gear ratio (3.23) ???
Noisy how?  Is it doing the jingle in 2wd?  Because there's a fix for that.
Also the codes are SU4 and SU5.  GU4 and GU5 are axle ratios.
Edited by newdude
On 12/6/2022 at 10:13 AM, SeanChev said:
My mistake I meant su4 vs su5 - with gu5 (3.23)gears
Thanks new dude, I have a 2020 trail boss with an AAM (su4) and 3.23 gears (GU5)
The front differential has ring and pinion noise between 30-40 mph - loud grinding.
Chevrolet dealership has looked at truck 5 times. GM told them to replace front differential assembly per warranty.
However GM does not currently have an assembly replacement? I am looking at avenues fro repair and possible get a (SU5) in it's place. This should be a direct fit replacement?????
    HWN808
    HWN808
  • Who's Online   3 Members, 0 Anonymous, 607 Guests (See full list)
