On 4/7/2020 at 12:11 PM, jlong1984 said:
It appears Carbon Black Metallic is a Fort Wayne only color, no matter the trim. All 45 trucks near my zip code are 1 VIN.
On 4/7/2020 at 12:23 PM, newdude said:
Front axles.
GM FRONT AXLE
AAM FRONT AXLE
Can you change out the Noisey Aam (gu4) and put in a gm(gu5) front axle?
10 hours ago, SeanChev said:
Can you change out the noisy AAM (gu4) and put in a gm (gu5) front axle with same gear ratio (3.23) ???
Noisy how?  Is it doing the jingle in 2wd?  Because there's a fix for that.
Also the codes are SU4 and SU5.  GU4 and GU5 are axle ratios.
Edited by newdude
On 12/6/2022 at 10:13 AM, SeanChev said:
My mistake I meant su4 vs su5 - with gu5 (3.23)gears
Thanks new dude, I have a 2020 trail boss with an AAM (su4) and 3.23 gears (GU5)
The front differential has ring and pinion noise between 30-40 mph - loud grinding.
Chevrolet dealership has looked at truck 5 times. GM told them to replace front differential assembly per warranty.
However GM does not currently have an assembly replacement? I am looking at avenues fro repair and possible get a (SU5) in it's place. This should be a direct fit replacement?????
    Bulldogger
    Bulldogger
  • Who's Online   5 Members, 0 Anonymous, 828 Guests (See full list)
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
