I have a 1996 Vortec 454 reading low oil pressure at idle after warm-up, 131K miles, well maintained. After warm-up it will read between 4-8 pounds at idle and makes the check gauge like flicker. Yesterday I swapped out the sending unit; no improvement.
Question: Is there a place by the oil filter or other that I can tap with a mechanical gauge to confirm the situation?  I am aware there were changes to the block in 1996, L-29/Gen. VI
I've researched and found some have gauge issues, others; sending unit; yet others having exactly the same symptom as me- it's actually the clearance in the bearings. I'm actually leaning towards it being bearing clearance issues and if so that sucks considering it being in a light duty truck,  lots of BBC's used in heavy-duty applications with good longevity.  I want to
Thank-you in advance.
Hook this John up and check oil pressure. Good pressure at filter means bad bearings. Bad pressure at filter means bad oil pump.
Attach mechanical gauge where the stock sending unit goes.  I have never replaced an oil pump and have it correct low oil pressure.  Back when I was serving my apprenticeship at a Chrysler dealership there was one winter where it seemed like I got two cars a week with the oil pressure idiot light coming on at hot idle.  The shop foreman would have me change the oil pump every time.  Everyone of those engines ended up 1 of 3 ways.  Crankshaft and bearings, or engine rebuild or traded in.  Oil pump didn't fix any of them.  I did get one van with a 318 that came in that had zero oil pressure.  It was over full of oil, yet not a drop came out when I removed the drain plug.  The van had been sitting for a few weeks during the coldest January in decades.  Was told to pull the engine, and when nothing came out of the oil pan I put the drain plug back in and went home.  Next morning I pulled the plug again, this time I got about a gallon of water then the oil.  Inside the engine was packed with that tan coloured sludge. That one got traded in.
  • 1 year later...
Hi Greg, following up to your oil pressure/gauge issue above as I have same issue, 1996 454 dually below 150k miles.  Any feedback would be great. Tks
  • 2 months later...
HELLO FELLOW READER  ... I HAVE A 1997 VORTEC 454 MOTOR WITH 9K ONLY  IN A MOTORHOME AND THE ISSUE I HAVE IS MY OIL GAUGE GOES FROM O TO 45 OR HIGHER OR 45 TO 0 AT IDLE ANY COMMENTS .
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
