I'm looking for detailed dimensions of the various inserts, for inside the box on the full length center console.  I have a mod/project in mind, but need to know the length/width of the bigger portions.
EDIT:  Please also let me know how deep they are too.
Edited by Ravenkeeper
Depth Measurement Request
You have me interested in hearing what the mod is now... also here are your measurements for one of two trays listed. I unfortunately don't own the other one. Would have been more accurate and in MM if my digital caliper wasn't at the Toyota dealership in my toolbox...
Subbed to the thread. Would love to hear about the mod..
Cheers
Cheers
Glad that you threw the depth measurement in there, forgot to ask for that one.  THX!!!
For sure man, I had 20 minutes and got bored. Interested in the mod, so I'll be lurking around here lol
Sent from my SM-N975U1 using Tapatalk
I have the Deeper, 2-pocket insert in my console. I will try to get you dimensions a little later when I have time to get out to the truck.
I want to say that Amazon has it at 7".
Going to use one of them to mount my CB and scanner inside the center console box.  Unless I find someone between now and then with a '14/'15 full length center console that they want to swap for the one in my '18.
Oh was your 14/15 center console for the removable cupholder, were you planning to mount the CB underneath it? Also thanks for @ mentioning me to fill me in. It sounds like a pretty sweet idea.
My 15 had the moveable cupholder and my CB and scanner was between the cupholder (in the forward most position) and the center box.  Now, I'm looking at mounting them inside the box.
Oh okay gotcha. TinkeringFox had a video on youtube on how to turn the gen2 console with non movable cupholder into one that moves. I personally want a 14/15 upper so I can just move the cupholders away. That will eventually be where I keep my handgun.
I was looking for either a full console, from a 14/15, or the upper half of the front.  I would like to keep the cupholder, so I'm resorting to put them in the box.  I'm also looking for an inexpensive way to keep them cool, maybe a couple/few fans, and/or maybe ducting some AC to them, we'll see.
That wouldnt be a bad idea using the AC ducting but it would have significantly adverse effects come winter when your heater goes full blast on 90... so youd have to account for that. I'd vote for PC fans. They can be had for 5-12 bucks, and you can simply splice them into a wire powering your radios. I think youd be able to measure the temperatures to find out if a pc fan would do the job
  • 11 months later...
On 4/15/2020 at 8:25 PM, Ravenkeeper said:
So I had ordered the insert (pictured above), received it, built my workbench, and started to do the CB/Scanner mount in the center console like I wanted to.  BUT, I laid both radios with the insert, and outer most measurement of the insert is the same as both radios.  🤬  Time for a new plan or finding a way to alter this plan to work.
Can you share a link for where you got that particular tray?
Off the top of my head, don't remember.  I'm thinking Amazon, but let me confirm that when I get home from work.
    LeeBob
    LeeBob
  • Who's Online   3 Members, 0 Anonymous, 1,157 Guests (See full list)
