Remote start not cranking
Do you mean it turns over but doesn't start/run?
Are you sure you are using the FOB correctly?
Is it the original FOB?
Yes as far I as know truck came with two remotes......one factory and one aftermarket one "code alarm"...the aftermarket fob doesn't do anything....the factory remote I can hit lock 3 times and truck starts then shuts off
Is your check engine (Service Engine Soon) light on ?  The factory remote start will not work if there is a fault. If it is an aftermarket unit, you will need to find out what make and model it is before you can even begin to troubleshoot it.
    DroppingDiesel
    DroppingDiesel
  • Who's Online   4 Members, 1 Anonymous, 994 Guests (See full list)
