Add a leaf, leveling kit, and new shocks
I have a 2015 silverado 1500 lt z71 that is bone stock. I'm looking to add a leaf to the rear, level it, and also need new shocks as I have the ranchero ones and was thinking of getting the bilstein shocks all the way around.
Was gonna use the zone add a leaf kit.
What leveling kit, and setting on shocks
What leveling kit, and setting on shocks should I use?
IMG_20200419_150116.jpg.tar.gz
I did the zone add a leafs. I love them. I also did the ready lift 2.25 level with control arms. Good option but may be better out there. I have stock shocks all around but will advise getting shock extenders if budget is tight or just get a set of longer shocks. All around i love the look and ridea9887e27f3236b3a9e5f754b464c9c26.jpg
Sent from my SM-G950U using Tapatalk
    Fishboat
    Fishboat
  • Who's Online   4 Members, 0 Anonymous, 556 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
