I just bought a 2019 with bench/center console. I have the power on the back but none inside the top console. My 2015 had usb - this one does not. Has anyone ran power to their center console so you can charge a phone in it vs having a cord hang from the dash. Maybe I am missing something.
Edited by Tnbeast
I did this.  I relocated the stock USB charging plate into the bench seat middle compartment.The shop I used then routed the power to it.  From there I ordered the identical USB charging plate and placed it in the original portion on the dash with no power hooked up to it.  Using it as a dummy cover.
There's a thread on here somewhere where he tapped into a line somewhere to add a USB inside the top.
So - here's a question.  Is the wiring harness there already?  I have a custom, and do not have the power in the back seat by the vents, but, would love a USB for charging only for my minions back there.
There is no power under the seat in a custom model. I am waiting on a plug that another member on here sold me to hook up power in the console
Apologies for reviving an old thread. I have out a full console into my 2019 Custom. I'm looking to find this harness. Do you happen to know the part # for it?
  • 8 months later...
  • 10 months later...
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,836 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
