2020 Elevation De-Badge
  • 1 month later...
Is the "GMC" on the tailgate on there with tape, or are they bolted in?  I have the fancy double tailgate if that makes a difference.   I am looking to take everything off but the GMC in the grille and the badges up by the mirrors...  Thanks for the help.
I'll definitely be debadging my elevation soon... Will post pics
Sent from my SM-N975U using Tapatalk
Looking at these clean debadged trucks... i suddenly notice the glaring silver lugnuts.  Why GMC? WHY?  Gotta upgrade them nuts now boys.
Ive got plans to plasti-dip the elevation badges black, not sure what to do on the Duramax badge.  Thinking carbon fiber vinyl for the GMC logos and replacing wood trim inside with carbon fiber as well...
Not sure what to do with the x-31 badges... they be a giant pain to plastidip...
Hello. I reviewed several videos from YouTube.com on this topic. I ended up using 30lb fishing line, a heat gun(already had), and Goof Off (already had). 1. Heated up Chevrolet Silverado & LT signage, used fishing line to run it between letters and body(pulling out), used Goof Off to remove the residue adhesive on the body, washed the truck, used a bit of polish on the areas where I removed signage, all it now looks good. Also replaced yellow bowtie w/ black one. Line-X bed liner,  CB radio, and Weathertech mats added as well.  Still have plans but for now OK.
  • 4 weeks later...
Blacked em out... but left them on.  Gotta get rid of the Sierra on the tailgate or something...
