Check it out...
• Regular Cab
• Short Box
• 4WD
Z85 Base
• Five-speed manual transmission with overdrive
• Z85 Suspension Package
Exterior: Dark Green Metallic
Interior: Medium Dark Pewter Cloth
• Air conditioning, front manual (C60) $0.00
• Differential, automatic, | locking, rear (G80) $270.00
• Engine, 2.8L DOHC,, 4-cylinder, MFI (175 HP [130.5 kW] @ 5600 rpm, 185 lb.-ft. [249.7 N-m] @ 2800 rpm) (LK5) $0.00
• Floor covering, color-keyed carpeting (B30) $70.00
• Floormats, includes front rubberized vinyl floormats (B32) $25.00
• Pickup box, Fleetside, all-welded steel with double wall construction and corrosion protection with 8 cargo tie-downs and tailgate, locking, 2-position (E63) $0.00
• Rear axle, 4.10 ratio (GT5) $0.00
• Recovery hooks, 2 front, frame-mounted, | (V76) $50.00
• Regular production accessory, Bed rails, | Dark Smoke Gray Powder Coat (SPO-supplied, dealer installed) (RDG) $175.00
• SOLID PAINT (ZY1) $0.00
• Sound system, ETR AM/FM stereo with 6-disc CD changer, includes seek-and-scan, digital clock and auto-tone control, speed compensated volume, TheftLock and Radio Data System (RDS) and 6-speakers (UC6) $395.00
• Transmission, 5-speed manual with overdrive (MA5) $0.00
Just a little over $19K. Kind of pricey, but it is a truck I would be happy with. You can only get a 4WD regular cab Ranger with the Edge trim level, which I am not fond of, and the Colorado is cheaper than the Dakota and gets better gas mileage.
