Just wanted to report on some work I did today on my truck. It's a high country so I think that comes packaged with the Z60 smooth ride suspension. I noticed that the overloads come into play far too often and make the rear end a bit jarring. Its not too difficult to conceptualize actually. The leafs are doing their job oscillating but then they strike the rubber pads on the overload and the party is over. Those overloads are so stiff.
I see two benefits to those things:
1) high payload (not me - 99% of the time)
2) axle wrap (especially with a torquey 6.2)
So, I pulled em. Left the blocks though. Netted .75" of drop. Also replaced the stock blown shocks with Bilstein 5100s. The result:
Fantastic ride quality! The edge of all the little bumps is gone. The big bumps...pshh...what big bumps. Soaks em right up now. Weight transfer during slow speed transitions like in parking lots or neighborhoods is more flat. It's a bit less eager to oversteer too.
The bad: axle wrap/slight vibes. Might be pinion angle but I doubt .75" would really cause that. Plus I did this to my QC Ram 5.7 that had a long a** driveshaft and it didn't get any vibes.
I was already planning on getting Roadmaster Active Suspension and now I'm committed. They basically act as a three in one sway bar, overload spring, and a traction bar. Tons of F150 ecoboost guys use em to combat the torque rich axle wrap from a dig.
Anyways, terrible at documenting things so this isn't a write up, just wanted to share my results.
Edited by lucas287
UPDATE: I've driven around for a few days now and I've introduced vibrations that we're never there before! :( Right off idle, less than 1500 RPM, I now have some vibes. on the highway - you guessed it - it vibrates. In town - yep - it vibrates. I double-checked the torque on my u-bolts (100 ft lbs) and I'm running 30 PSI air pressure in the back.
 I think a combination of lowering the ride height with decreased spring rate is causing significant axle wrap which amplifies operating angle issues with u-joints. I was inspecting my overloads and it seems like they were called into action A LOT and I think they were acting a quasi-traction bar limiting how much the leafs twist under torque.
I watched a few videos showing just how much axle wrap exists even with the overloads and it's pretty crazy. And those videos were with the 5.3. The 6.2 makes so much more low end torque it's ridiculous, making the problem worse. F150  ecoboost guys really struggle with axle wrap too - because of all that torque! I also firmly believe that's why placing leaf spring clamps forward of the axle helps with vibes. It increases spring rate by engaging the overload limiting the pinion from creeping up.
Going against my better judgement, I'm going to change more than one variable tonight.
1) I will put the overloads back...
2) remove the lift blocks
3) place leaf spring clamps forward of the axle
4) tighten the SHI* out of my u-bolts. Probably need new ones anyway they're arguably too long and they're TTY.
I'll report back if anything has changed.
Oh yeah - if time permits, I will take some readings of my static pinion and t-case angle. Ideally, they should be equal but opposite. For example, (-3) on the t-case and (+3) on the pinion. That's in a perfect world though, maybe on a 4 link setup where the pinion doesn't climb under load. I'll aim for the pinion being point down 1 degree lower than the t-case. Maybe (-3) and (+2) which will allow for 2 degrees of pinion creep without getting too out of hand.
12 hours ago, flyingfool said:
pictures???
I suck at documenting work. I'm also a member on thelawnforum and I always forgot to update my journal over there! I'll snap some pics before I put them back in and then after removing the blocks.
I only dropped about .75". The blocks should drop 1.25".
Here's an update. Last night I just focused on measuring and correcting angles.
It took forever to get the yoke and pinion flanges at just the right angle to get accurate readings, but I got it pretty darn close.
1) Zero'd out my angle finder on the yoke off the t-case.
2) Then I squared it up on my driveshaft. 2.5 degree difference. (For your visualization, imagine the t-case pointed downwards 5 degrees. The driveshaft was half that at 2.5 degrees.)
3) using a deep socket on the cup of the u-joint in the pinion flange, I measured the pinion angle. 2.7 degrees.
This means my operating angles of the u-joints themselves are within spec, but they are not equal. On a one-piece driveshaft, the pinion angle should be parallel to the t-case/transmission yoke angle.
Rummaged around in my garage and found some 2 degree axle shims. With my impact I loosened the u-bolts and put my floor jack under the leaf pack with the help of a scrap 4x4 wood block. Created just enough separation to slide them inline with the pin. Dropped it down, tightened it back up, and torqued to 100 lb ft. Repeat the other side.
Results?
Zero'd the gauge on the t-case, measured the pinion angle - BOOM - only .7 degrees difference. This is actually ideal as the pinion will climb under torque.
Took her for a drive and the majority of the low speed vibes are gone! Highway is still there though. My shi* Goodyear LS2 tires aren't helping though even though I had them shaved.
Next I will put the overloads back in and remove the block and drive it for a few days to evaluate before using some leaf spring clamps.
Put my overloads back in last night. Was going to put the 2 degree pinion shims back in but realized the alignment bolt that both clamps the leafs together and centers on the axle doesn't protrude enough through the shims to actually engage with the hole in the axle.
For now, it's quite a bit better. The axle doesn't wrap NEARLY as bad, but still feel it when I'm aggressive on accel and it's still there on decel too.
Hoepfully these bad boys are the solution. They should be hear Friday and I'll report back. Probably start a new thread actually.
https://www.amazon.com/Hellwig-2002-Traction-Control-Spring/dp/B0119G0E5O
Are you still considering getting the Roadmaster Active Suspension?
On 6/12/2020 at 9:54 PM, Eddie 70 said:
Get them installed yet?
I did. And I did a write up on them. I was pumped about them at first! Thought they worked really well but I'm thinking that was just a placebo effect after all. I drove on them for two weeks fiddling with the preload and there wasnt any way to install them without negatively impacting ride quality. Do they control wrap? Yes. But that's because they work by increasing spring rate.
Maybe?? Idk. The direction I'm leaning is to get legit traction/long/ladder bars. Specifically the rough country ones.
 there has been one forum user who installed them, and loved it..  but your 6.2 power might be more than they can handle. I think you need drag racing style set up
I've had them for awhile but I wanted to see if someone elese was experiencing some of the things that I was.
Just out of curiosity, what are you experiencing??
Yeah I think so too. I'm not doing anything crazy to this engine (famous last words) except E85 conversion, full custom tune, and maybe a muffler delete. But even with that I'm looking at 500 ft lb of torque. That's big block level torque for the same puny leaf springs that go on a 4.3 model.
I'm pretty dead set on Rough Country's traction bars. I've done lots of research comparing them to caltracs and the likes and I think they'll be best for my goals, which is really just zero axle wrap. I don't care if I always blow the tires off since it's kinda fun :) I can always put it in 4wd if I want to hook up.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
