I wouldn't put a lot of faith in the gauge, based on the reports on multiple forums.
Fill it, run it for 3000 - 4000 miles and refill and do a hand calc.
Remember, that the initial warnings are range/miles to empty.
Once it thinks it's empty, there is still 500 miles til the 65 mph speed limit. Should be more than enough miles to get it to the next fuel stop and a def refill location without having any limit on speed.
Thanks for the info on this.
Just as an update, I put almost 1300 daily driven miles on the truck, haven't towed anything yet, and just tried to add some DEF. Ended up getting about 1/2 to 3/4 of a gallon in it.
Happy to hear you’re getting that kind of range not towing. I just did a 5k round trip towing and hand calculated each full up. Consistently saw between 300-400 per gallon depending on how fast and how much climbing.
Time to update your sig and avatar with the new ride info
Done! Thanks!
10 hours ago, cNate said:
Done! Thanks!
Avatar info update visible (nice truck !)
I'm guessing sigs don't show on tapatalk, but they do in web browser and your sig still has the 2014 info -
2014 GMC Sierra SLT 4x4 CCSB 5.3L 4.10 Yukon gears, Superchips Tune
6" BDS with Toyo R/T 35x12.50r20 on OEM 20x9 wheels
AMP Research Power Steps, G4 Elite Fold-A-Cover, Rockford Fosgate 10" 500
GM DQS Tow Mirror Upgrade, Prodigy Trailer Break, Tow Spring
Build Thread
Would you continue to track the mileage?  I am wondering if there is something different between the trucks made last fall and this spring.  I only get about 500 miles per gallon of DEF even when I don't tow anything.
I just did the module reprogramming recall and topped off my DEF. I’m going to top it off after 1k miles and see what the mileage change is.
Yeah i'll keep an eye on it.
  • 3 weeks later...
So I’ve tracked about 1,600 miles since I topped off the DEF and did the module reprogram. Most of that was towing around California and out to Lake Havasu and back. Hit some grades and average slightly better on my MPG than my last hand calc on def (12 MPG versus my 11 MPG). Got 450 miles per gallon. Better than the 300-400 each time I hand calculated after 1k miles. The sensor also reads accurately all the time now. Will be i retesting to see if I can get close to the 1k per gal mark not towing. Been working remote due to covid and basically only leave if I have the travel trailer in tow these days.
I just picked up my new 2500 on Friday (7/31/20).  I have 148 miles and the gauge has gone from full to 1/4 full.  I'm wondering if its the gauge or actually using that much DEF?
Hesitated quite a bit on a diesel due to all emission regulation equipment.  Pretty frustrating for 2 days in...
Hi cr2256,   I would take to the dealership and see if it has the software upgrades they have released.  That should help fix the gauge issue you are seeing.  While my DEF usage isn't great, it is definitely not that bad so I think it probably doesn't have the latest software.  Once you have that fixed, if you would track your DEF usage for me, I would really appreciate it.  I am trying to figure out if my pickup is one off or if across the installed base, everyone is not getting good mileage per gallon of DEF.
Thanks, I'll be taking it in early next week.  I'll let everyone know if that's what they perform.
Also note that it's a 7/2020 build.  Came off the train this last Wednesday in Georgia.  Don't know if there is any relationship between build date and excessive usage.
Our family loves the truck besides this.
Fill the def tank and do your own test.
I probably wasn't full when delivered.
Gauge isn't a typical variable gauge -- it's trying to provide some estimate of how remaining range til empty.
If not full when put into service the calcs will give strange results.
DEF tank not full has caused huge amounts of grief ever since it came in use on duramax for the 2011 model year.
From https://gm-techlink.com/?p=13143
Segmented DEF Level Gauge
The current 2020 Silverado 1500 and Sierra 1500 models have a DEF level gauge on the instrument cluster that provides drivers with a representation of how much DEF is in the DEF tank up. (Fig. 2) The DEF level gauge does not operate like a typical float-style gauge that is used in a fuel tank. The Engine Control Module (ECM) monitors the DEF level and consumption rate in order to calculate an estimated range. DEF levels are detected by the DEF level sensor.
F02-DEF-2.pngFig. 2
There may be some fluctuation in the amount of DEF represented on the DEF level gauge. After filling the DEF tank, it may take a few key cycles to register the correct amount in the DEF tank. With the new segmented DEF level gauge, it is possible that after adding 5 gallons (18.9 L) of DEF that the gauge reads as a full tank after the fill event. However, if the actual level of DEF is just entering the last segment on the gauge, the gauge is likely to drop by one segment shortly after driving after the fill event. As a result, a driver could have an initial impression that the vehicle consumes an excessive amount of DEF.
@redwngr, thanks and that is possible. The gauge showed full but they didn't confirm that it was filled up during dealer prep.  It's possible that it wasn't full to begin with.  I need to have something else looked at so ill let them fill it and go from there.
Thanks
    needafix
    needafix
  • Who's Online   5 Members, 0 Anonymous, 590 Guests (See full list)
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
