Multiple issues I think stem from same problem as they happened almost simultaneously: front diff doesn’t engage 4wd; dead battery after sitting for at least 3 days; steering pulling left or right when decelerating or accelerating (electric power steering). Thinking some electrical or computer issue is to blame for everything.
2017 RCSB Silverado 5.3 4wd WT (manual T-case). Heads, cam, DOD delete, Whipple, LT headers, upgraded ignition system, etc. Also, Odyssey battery, 300amp alternator, small stereo system (1800 watts w/factory infotainment 8” screen).
I replied to an off topic post in this forum with my issues, and after performing some troubleshooting on my own. But after searching for solutions I’m left with the same problems and no direction on how to proceed.
Troubleshooting so far:
1.) verified that transfer case is engaging properly. It is.
2.) checked to see if the front diff actuator is engaging the front diff. It is not.
3.) checked 4wd Trec fuse visually and with continuity test. It is perfect.
4.) performed amperage draw test at the battery negative terminal and found 5 amp draw with key off.
5.) disconnected the 3 fuse boxes - under hood, leftside, right side - to pinpoint which fuse box has thecircuit drawing power. Right side fuse box at dash is source.
6.) pulled infotainment fuse. Door speakers made a popping noise. Battery draw reduced to 0.01 amps.
So, I know the source of the drain but unsure what to do next. I thought BCM would monitor battery drain and prevent the truck from going dead. So, I think I have a BCM issue that’s also affecting the 4wd actuator and electric steering logic. Thoughts on what to do next?
Sounds like your amp must not be turning off when you turn the truck off. I don't know how you have it wired but when you pulled the fuse to the infotainment system it let you know it had been powered on. A 5 amp draw is a big draw. This kind of draw will kill a battery in 3 days time. A weak battery has been known to cause issues. I don't know much about stereo systems but it seems to me that the trigger wire is keeping the amp turned on.
I thought amps were draining battery too.
they get signal/remote wire from the factory infotainment/radio.
Pulled fuses from amps. Disconnected power wire from amps.
2.5 amp draw from infotainment still exists. Remove infotainment fuse and battery draw drops to 0.01.
Noticed some other things, but unsure if it’s normal: opening passenger door doesn’t turn the accessories off, but opening the drivers door does turn everything off; opening the drivers door after the truck has been off for several hours turns on the dashboard (gauge cluster, infotainment center, climate control knobs and buttons). Is that normal?
Also, pulled dash area by dash speakers and verified G218 and G210 grounds were good.
Keep thinking BCM isn’t going to sleep like it should. Which leads me to think there is some stupid little part that isn’t sending a trigger signal like it should.
That is all normal.
Thanks for letting me know.
I can stop going down that rabbit hole now.
Just weird to have multiple problems arise almost simultaneously. So, I thought they must originate from a single source.
Have a transfer case position sensor on order to see if that solves the 4wd issue. Will unplug the EPS to see if that eliminates the unpredictable steering. Have a call in with my stereo installer to see if he  has any insight for battery drain. Meanwhile, I just have the fuse removed.
any other guidance still open for!
You are very welcome.
Have you gone through all of the ground points?
G218 and G210 under the dash are good.  I haven't gone through the rest. Not sure where they are.
Update:
Everything seems to be working correctly now.
1.) Front diff actuator replaced and 4wd is working properly
2.) Performed a relearn of the PSCM. For some reason the rack and the steering wheel lost center and each other's position. Truck no longer wandering on acceleration and deceleration
3.) Reset the BCM and cleared all codes, and it seems to have remedied the battery drain issue.
    • Done. I'll have more productive conversations with a hickory stump. Carry on! Keep the blindfolds on TIGHT!
    • This again?   https://www.reuters.com/fact-check/us-capitol-attack-rioters-had-weapons-including-firearms-2025-01-16/   Think Reuters is biased?  Check their rating https://mediabiasfactcheck.com/reuters/
    • I found an odor eliminator spray that neutralizes unwanted smells pretty well. Using it with the car's AC running helps to distribute it evenly around the cabin.
    • WTI futures / speculation is just that. WTI futures <> current 4-7% inflation and national average gas price over $4.00/gallon.   The spot price, at delivery, is currently $87-$95/barrel which is why gas prices remain high.   Edit: oH mY gOd mEnTaL BrEaKdoWn In tHE pOsT aBOve mInE. TrUmpErS goNnA tRumP
    • He does, actually. In another unrelated video he mentions the president called him in the middle of the night to relay some information on a cause (religious based) that he's invested in. Glenn expressed concern that another leftist administration could wield too much power with some procedure the Pentagon was using, classifying certain religions a certain way. Being that he is LDS (Latter Day Saints), he gets hate all the time from ALL over the political spectrum, so he's invested in this. Trump called him back at 5AM to tell him he had made some changes to that classification.   So, yes, they are and have been in contact regularly since the start of the administration. Glenn, of course, always asks his permission before discussing anything on the air.   I already spent an hour or more just searching for these videos. I may have my numbers wrong - I'm not a numbers guy. It may have been a MILLION barrels, not 1.5. The point is, our President, by his actions, gives a crap about America, and US - this is completely OPPOSITE the actions of the prior administration who projected hatred for anyone who wasn't following the left's edicts in lock-step.   Remember, they called January 6th an "Insurrection", when there were ZERO weapons among the crowd, undercover FBI agents agitating the crowd, along with paid leftists acting as aggressors, egging the crowd on in an attempt to whip everyone into a frenzy. It's all been proven.  Pelosi refused Trumps request for more National Guard troops. This smells 100% like an inside job for those with critical thinking skills. Only a handful of guys in the crowd got wrapped up in that, thankfully, but EVERYONE was searched out based on cell phone data, and charges were brought against many. And 6 or so people were locked up and left in solitary confinement for YEARS with ZERO due process!! If you give the slightest crap about our Nation, REGARDLESS of your political leanings, this should frighten you to your core. This is what men suffered, bled, fought, and died against 250 years ago!   This has gone FAR BEYOND left vs. right. This is a  threat to America, and our way of life. This is PRECISELY why Trump, a BILLIONAIRE who could have chosen to take Melania and sit on some tropical island that he could afford to buy himself and RELAX, instead chose to run for office, get hate from literally every corner of the media, get ATTEMPTS on his LIFE constantly, and begin to repair some of the severe damage that's been done to this Great Nation.   I don't know why I bother wasting my precious time here. Everyone has their minds made up. They won't realize we all were correct until it's too late ... after they elect another tyrant that hates America to office (Obama), or another puppet whose administration is secretly running the show behind the scenes (Biden).
