pre cut vinyl for GMC emblems
Can someone recommend some? I got a kit of Amazon and it still showed red at the edges, looked to be cut just a little too small.
Evin
I took mine to my local sign and vinyl shop. They put on a black vinyl that is great quality and came out great. I tried to install once myself and struggled with fit and bubbles. Wrapped front and back GMC emblems for 20 bucks a piece.
That’s looks great!
How hard is it to remove the front GMC from the grill?
Did you reinstall the same rear letters?
    • *Your
