2002 SILVERADO 5.3 VORTEC. P0200 CODE INJECTOR PROBLEM. DISCONNECTED ALL INJECTERS. GOT POWER ON LEFT SIDE,NO POWER ON RIGHT SIDE. WHAT UP? SHORT IN HARNESS OR PCM. ANY HELP????
We in the trades call ringing out a circuit using a battery powered door  buzzer to check out any automotive circuits. A ringer is easier to use since you dont have to look at DVM.
Injectors are not powered by PCM. Check "Inj B" 15a in the underhood electrical center. Power for injectors 2 and 4 are wired together, 6 and 8 together but all four are on the same fuse. PCM does the ground side of all injectors individually.
4 hours ago, Paul Christman said:
YES BLOWS FUSE EVERY TIME I TURN ON KEY.NOW WHAT??
That means your circuit is shorted to ground. You need to trace the wires back and see where it is (more than likely) touching the engine block.
Here are a few places I have found causing this.
On the passenger side of the engine there is a harness that runs down in the front. Check that harness and see if it is shorting out. Also, Check at the back of the alternator. Some times you will find a short there as well. Another place is where the harness runs down between the power steering pipes coming out of the power steering pump. That's on the drivers side of the engine.
THANK YOU. I'LL TRY AND FIND IT BEFORE I CALL THE TOW TRUCK TO TAKE TO THE SHOP. EVERYBODY WAS TELLING ME THINGS TO LOOK FOR, BUT NO ONE WAS TELLING ME WHERE TO LOOK. THANK YOU. I'LL LET YOU KNOK WHAT I FIND. DISABLED CAN'T REALLY AFORD THE SHOP. BUT NEED MY TRUCK.. FAR FROM WHAT THIS SHADE TREE DIY IS USED TO. CAN TEAR MY 85 SILVERADO APART FROM BUMPER TO BUMPER AND PUT BACK TOGATHER  I'M OLD SCHOOL.....
  • 4 years later...
I just want to say I’m glad that I found this forum because after constant testing it ended up a blown fuse but just so happen to be a fuse labeled only with a “ * “ now she is up an running but changed out the injectors and she is even better thanks for all the help
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
