So I had my Trans rebuilt.  When the builder test drove it after rebuild he left a o2 bank 2 sensor unplugged.  He Drove it for a few miles before truck stared running bad, idling bad, smoking and threw p0300 misfire code.  I think this was because it ran really rich because of the missing o2 on one side.  We have changed the plugs they were wet as can be. It idles better but still smokes and low on power. Still has p0300.
 Next steps are to change all four o2 sensors. I think I might have to replace the catalytic converters as well due to over fueling. I think this is the power issue.
Question is anyone ever experience this or feel like it could be something else?
An unplugged o2 sensor will not cause all these problems. Something else is going on here.
If an o2 sensor fails (or unplugged) the computer will just revert to in simple terms a pre-made air/fuel calibration that will be good enough to get you somewhere. The computer is not going to start dumping in extra fuel because a sensor died or didn't get plugged in. If a sensor was failing and started reporting incorrect readings while plugged in, then that could cause a problem with a lean or fuel mixture but if the sensor was not even there it can't get a reading off of that bank to do anything.
P0300 means multiple cylinders are having a misfire. A scan tool will let you pinpoint which cylinders to look at to help further figure out where to look. You can also use a scan tool to look at fuel trims to determine which bank of cylinders the issues might be on as well. And you can look at the o2 sensor operation before you possibly waste $200 on new sensors.
Exactly. You're not having an 02 sensor problem. I have an idea of what you have going on though. I have seen this several times when people get their trans replaced. They will bring them to the dealership after they have been replaced with exactly what you have going on.
The wiring harness to the High pressure fuel pump and the injectors are underneath the manifold and they run over the back of the engine. Sometimes when the transmission is reinstalled it will pinch the harness between the engine and the transmission. This will cause a P0300 and a reduced power concern.
It could have been disconnected by accident when the transmission was removed as well.
Start there IMO
Edited by carnau
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 5,058 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
