2017 Silvy Headlight Bulbs Replacement
I'm wondering if anyone has ever replaced these with anything brighter?
They are super bright already, but for those of us who have tinted our headlights, it would be nice to have them brighten up a bit. If there's no options to do so, i'd rather keep the lights dim with the tint because of how amazing it looks! But it would be nice to go brighter without having to add a lightbar or anything.
Anyone familiar with any options out there? Preferrably 6500k, if they exist.
  • Replies 32
If you have HIDs, they are Philips D5S 25W bulbs with a color temp of 4500K-4800K.
Color temp will do nothing for brightness and going to 6500K is going to start turning blue when seen from a distance. Immediate light output out front of your vehicle will still look bright white.
If you want brighter bulbs then you need to increase the wattage. DiodeDynamics has a plug and play bulb that is 35W and can be purchased in 5000K and 6000K color temp options.
Morimotos also offer 35W bulbs but they are a bit higher on the color temp scale coming in at 5500K and 6500K.
Morimoto also has a 55W kit but I believe at that point you now have to upgrade your ballast to go up to 55W. Don't quite me on that because I don't have any experience with the Morimoto 55W setup. I did upgrade to the DiodeDynamics 35W 5000K HID bulbs and so far I'm extremely pleased. Definitely more light output with the increased lumens but looks same as factory at 5000K.
Do you have any before and after pictures of the light beams on a wall or garage door or something? I think its the Morimoto kit I found last night that had some pretty bad long term reviews, so i'm curious. Also, how long ago did you install yours?
I do not but it's not hard to change the driver side bulb for the purpose of that. If I remember later, I'll swap one out and point it at my garage door when it's dark out, see if it makes a good side-by-side comparison.
I put them in last week so I haven't had them in long.
Oh thats super new! Are your headlights tinted or untinted?
I think I found your problem.................
Are you talking about the headlights being tinted? I know they are tinted, i tinted them, and i also mentioned that im fine with the brightness if there's nothing brighter but, i would of course prefer brighter. I like the tinted look, but i also like bright lights. If i have to pick one, i pick the tint and dim lights.
That Lasfit looks pretty good! I took screenshots of the same part of the road you were on with each and compared them. I have one question that the video (due to quality) makes it really hard to tell.
It appears as though the stock HID lights might be better further down the road where the lasfit LED's dont do as good, but do significantly better up close. I paused the video's before you passed that factory looking thing on the left. The road looks like it was repaved and so there's a line, as soon as that disappeared under your hood, i paused it and took the screenshots. After comparing them and rewatching the video, it looked like i might be seeing more detail at a distance with stock vs lasfit. Can you confirm?
Can you post a link to the DiodeDynamics bulbs? When i look by vehicle on the site, the only headlights are replacement OEM HID's
So i've done some looking around and it seems that most people are saying that HID's are brighter than LED's. Is this true?
I found that the Lasfit lights, they are LED and each bulb is 5000 lumens.
HID Concepts has an HID set thats 3600 lumens which is the brightest HID's i can find.
HID Concepts has an LED set but they dont list the lumens, and they are actually telling customers that the HID's are brighter.
What i've found between lastfit and HID Concepts is that when you look for HID, i cant find higher than 3600 (typically 3200 to 3400) but lumens for LED's are higher, yet everyone says HID's are brighter?
I'm feeling like a 3000 lumen HID vs a 3000 lumen LED and the HID would appear brighter (maybe the light carries further?), but for some reason these D5S's are being made brighter as LED's than HID's so the LED's are actually brighter than the HID's if the lumens are higher? I'm a bit confused if you couldnt tell haha
https://www.diodedynamics.com/replacement-oem-hid-bulbs-for-2016-2019-chevrolet-silverado-1500-pair.html
By brighter it may be meant in a way that HIDs will throw light further down the road than LEDs would in the same projector housing.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 528 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
