2017 Silvy Headlight Bulbs Replacement
6 hours ago, fondupot said:
@Mike_DThanks for the shout out. I am very pleased with the Lasfit D5S-LED conversion.
Thanks @fondupot, i meant to ask you how they are holding up for you. You dont by chance have your headlights tinted do you?
If i'm doing the math right... Then the stock headlights are 2000 lumens total (1k per bulb). After applying the 20% tint to the headlights, that means they are now only 400 lumens. If I upgraded to the 35w HID's which are 3000 lumens without tint (1500 per bulb), then they would be 600 lumens with the tint, still not even half way to stock!
Now with the Lasfit being 10,000 lumens total (5k per bulb), that would mean that while tinted, 2000 lumens would make it through (1k per bulb), which matches the stock lights without tint. Did i botch my math? If not, then the Lasfit's are going to be absolutely perfect (until a fan dies)!
  • Replies 32
They are holding up great. No issues.
I do not have any headlight tint. Your math sounds right, but tint may add some more scattering of the light as well as reduced lumen output.
But if you want the best output....nix the headlight tint. My 2 cents.
Eventually i'll get rid of the tint when i upgrade my headlights to something thats black inside. That'll get rid of my need to black out the headlights.
Either way, glad they are still working well, cant wait to install mine and see how well it works!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
